supercharger tuning question
Old Jun 5, 2006 | 03:34 PM
Gringo003's Avatar
B.B.C
Default supercharger tuning question
ok i have a 1990 civic with a d16y5 motor in it, i have a jackson racing supercharger that i plan on putting it in soon as i have everythign to tune it right, i have vtec e which is not hooked up or anythign the car is obd0. now my question is if i get a zdyne gold ecu and get the one wire vtec hook up will it engauge and be able to tune my supercharger well with it . i know its expensve but i have heard good things about it and by the time i convert to obd1 and get a tuned ecu it will practaly pay for the zdyne gold let me know what you think about this and how well you think it will work on my setup. thank you
Old Jun 5, 2006 | 05:19 PM
60-1EK's Avatar
Engineer at the source
Contact www.lhtperformance.net
John has been tuning Zdyne for longer than most people on this site. Not to mention he is a Zdyne dealer. Also, if you convert to OBD1, he has all the goods to convert to that and also is a Hondata dealer/tuner if you want to go that route.
Jason
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Jun 5, 2006 | 05:54 PM
Gringo003's Avatar
B.B.C
but would zdyne be able to tune the car right with no problems i would rather go that way cause if i converted and when hondata or whatever it would be a little more so id raher go zdyne. i just need to know if it will do a good job of running my car correctly and also how hard is it to tune these ecus? could i do it with my lab top and the directions they give you to do it or do you need further knowledge
Old Jun 6, 2006 | 09:40 AM
chi town brat's Avatar
! Ne shab'rud'ni !
I have zdyne with my vortech supercharged b16a which is currently non aftercooled and the zdyne stock forced inducted program is doing okay. we programmed the ecu to kick in my vtec after we wired for it.
John over at LHT has tuned a lot of cars using zdyne, he has moved away from obd0 from my understanding to move to a ecu program that can handle the whp he and others are pushing
for your JR set up the zdyne would be fine, the biggest part of the JR on a sohc set up from what I have been told is making sure your timing is correct
if you are an unexperienced tuner i would def recommend hiring someone who can tune
Old Jun 6, 2006 | 03:56 PM
Gringo003's Avatar
B.B.C
ok cool thanks, i dont want to run a ton of boost i want to run anywhere between 5-7 psi so hopefully the zdyne will be good for those low numbers.
Old Jun 6, 2006 | 04:00 PM
DAMPACHI's Avatar
Paul @ LHT Performance
Zdyne will be perfect for your application. Give us a call at the shop. 727 344 1800
Old Jun 6, 2006 | 06:00 PM
mtber's Avatar
Zdyne is a waste of money but it is an obd0 solution if you must keep an obd0 system.
There are plenty of affordable obd1 solutions such as crome.
Look into the tuner directory listed at:
https://www.tamparacing.com/forums/h...directory.html
Good Luck
Old Jun 6, 2006 | 07:06 PM
DAMPACHI's Avatar
Zdyne is a waste of money in your opinion but will work just fine for his setup. Dont be so close-minded.
Old Jun 6, 2006 | 09:59 PM
mtber's Avatar
I agree that it will work. But, why would you buy a obsolete fuel management system when you could buy a chipped obd1 ecu, obd0 to obd1 conversion harness & a obd1 distributor for around the same price ?
You and I both know that 90% of the "efi" tuners out there would choose to go with an obd1 system.
Old Jun 7, 2006 | 11:41 AM
MrLHT's Avatar
John @ LHT Performance
I still use and recomend Z dyne on OBD-0 cars, They work very well with no bugs or problems at all.They are true plug and play and will supports all a supercharged setup would need. We have found the Zdynes to be limited on injector size, I ,nor Bill at Zdyne could tell you why but much over 680cc injectors they don't control very well.
We use Hondata more these days as must cars we build and higher HP, and controls 1000+ injectors perfect. It's your choice, go with what your tuner suggests.
www.lhtperformance.net.
727 344 1800
*Turbocharging* Engine building* Tuning *Intercooler piping*exhausts* headers* clutches ,fabrication and much more
13 years in the same location.
** HONDATA Authorized Dealer+ Tuner **
01 Type R-647whp street car w' AC - Cover of turbo magazine Feb 2008
01 K20a INSIGHT - Cover of Honda Tuning magazine June 2008
2011 KR-Z K20 powered CR-Z -Cover of Honda Tuning magazine April 2011
