2NR Werks S2000 Lays Down 467whp/303tq
We finally rolled this 2003 S2000 which was brought up to us from a returning customer in Ft. Myers to the dyno for final tuning. This was a challenge because we had so many issues with heat being confined to the engine bay because so much of the downpipe was located there. After many designs of a heat shield was scrubbed and thrown into the pile, we fabricated the best one to do the job. Our original underhood temps were 350 degrees, after the new shield was made we were staying under 140 degrees even while on the dyno.
This is a stock F20C with a 2 mill head gasket, GT35R, 750 injectors, AEM EMS, 3" exhaust single exit exhaust and a stock looking car other than the Precision IC up front.
We orignally used a 4" downpipe, but changed to a 3" DP because our ground clearance was minimal.
Our first pull on 93 octane yielded 404whp and after 11 pulls we tweaked the final numbers of 467whp/304tq. at 13.5 PSI. That is 19 horsepower per pound of boost. Most production turbo setups produce 11-13 horsepower per pound of boost. This car is an animal as boost and VTEC engagement hit around 4200 RPM's.
Enjoy!
Enjoy!
"It's OK to Smoke V-8's" - Surgeon General
www.2NRWerks.com - NSX, S2000 & RSX specialist. AEM, Hondata Kpro & Crome tuning provider. Custom built F, K & B series motors. Custom "Safe" Nitrous Kits and NOS Refills (While-U-Wait). Suspension/Brake Specialists & Alignments for lowered cars. On the quest for 700whp S2000 roaming the streets early Spring.
To Schedule An Appointment Call: (813) 876-VTEC
<< Reputations are so overrated! Don't hate on me 'cause I build fast cars.
great job!
Racing Integration
LHT Performance
My tuner is named Alpha
Racing Integration
LHT Performance
I knew that beast would lay down some great numbers
as always great job guys...
Modified Racing
Street Tuning & Dyno Tuning the greater east coast area for over 10 years and running!
AEM/HONDATA/MOTEC/FAST/DEFI & More
EFI-101 Certified
(941)628-4988
EFI-101 Certified
(941)628-4988
very impressive, congrats!!!
http://www.inductionperformance.com/
R.I.P
Kevin "Slo_Si" Gonzalez
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
You will be missed and remembered forever!!!!
R.I.P
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
And he is for hire.
Now Keith has respect for 2NR Werks, after the months of flameing us, Scorpion.
Nice numbers on pump
What are the specs on the gt35 ?
A ton of people are cranking out awsome numbers on f20c setups now days.
A ton? I wasn't aware that there where that many F20's out there let alone a bunch of people going crazy with them. Guess I'm just not in the the know. Specs on the GT35 can be found out turbosbygarrett.com
