ls-vtec or ls turbo??
i need some help trying to decide wat would be better ls-vtec or ls turbo. the motor is an obd0 ls,81.25mm bore and itr pistons with arp rod bolts. if i go lsvtec should i rewire the car to obd1 or just get a vtec controller? which one would have more bang for my buck? thanks
Steve: (813) 810.4146 <~ call or text
well if your gonna stay ls turbo id change the pistons to lower compression, and if your going lsvtec your fine but will make less power, and no matter what you say... a vtec head flows a million times better than a non vtec.....
You can find me at the Track!
KJ built
ALPHA TUNED
Induction Performance 727.505.1423
* Engine Management Tuning, Track Setup, Consultation, Turbo Sales, Parts Sales (WorldWide)
ONLY SHOP IN TAMPA THAT TREATS YOUR CAR AS THEIR OWN
KJ built
ALPHA TUNED
would having the itr pistons really hamper the turbo or would the copression be to much strain on the rings?
itr pistons' compression ratio is too high, itr pistons are more for the naturally aspirated cars, you would need to run at least 9 0 1 compression pistons for a turbo, but you can still run a vtec with a low compression motor, but you wouldnt want to run the vtec with the low compression pistons and not run a turbo... my question is... how much money are you planning on spending throughout this WHOLE setup... from beginning to end... if you do it piece by piece, i would get your vtec head and ecu to go with it, then get your 9 0 1 pistons, then by your turbo... you are lookin to spend at least 350 for pistons, at least 1000+ for a little t3/t4 setup, and what ever your cost is on that vtec head with ecu. its all about how much hp you want and how much money you got.
i plan on spending between 1500 and 2500 possibly a little more. right now i have an obd0 and it will be changed to obd1 but if i buy the conversion harness i know i will need a 4 wire o2, but how would i hook up the vtec? or should i just get a obd1 engine harness and ecu?
you can get all that done with 1500 - 2500, i got the best idea for you yet... pm blown99civicsi, he deals with this everyday and is one of the best out there... he can also get you EVERYTHING you need for this setup. trust me... pm him, he can answer any question you can throw at him.
