So im building a block for a new ls/vtec
OK im picking up an ls block with a fresh hone micropolished crANK AND ACL race bearings... havent found out what all bearing but i will hopefully.. i think they are mai bearings... what my question is...what all bearings should i replace? WHat else is there? i know big end bearings? i know the term but dont know where they go its a bare block and im buying aftermarket rods and pistons so i dont need rod bearings right? i pretty much want to relace everything.... this is a boosted application.... dont really want to spend a g for sleeving so i guess ill have to settle for a block gaurd
OEM B16 Bearings FTW ..
OEM ITR Waterpump
OEM ITR Oil Pump
OEM Bearings
Endyn Blockgaurd
Also make sure you get the block professionally assembled by someone who knows what they are doing ...
OEM ITR Waterpump
OEM ITR Oil Pump
OEM Bearings
Endyn Blockgaurd
Hondata saves lives
Hondata saves lives
Stay away from the race bearings on a street motor, the clearances are usually a little too loose.
Gracie Barra Clearwater
and a blockguard is far from necessary. if you buy the ACL bearing kit it will come with all the main and rod bearings along with thrust washers. even though youre using aftermarket rods you still need to use bearings, if you dont know that have someone help you build it for your own sake
From your questions, it's clear you don't have experience in engine building. Avoid a disaster. Get some help. If, however, you are in the early stages of gathering information to attempt your first build, keep gathering, ask lots of questions, crack the service manual, read and reread....
Originally Posted by 99B16Si
+1
^^ built one of my old ls vtec short blocks...still runs to this day :-0 50k miles later
RIP Robert Kolp aka 00ek 4/07
_Jake D
_Jake D
_Jake D
_Jake D
Originally Posted by Cold_Beer
The only way to learn is to just do it.
i love AUTOZONE
i love AUTOZONE
Originally Posted by rangcrx
wow......: o(
??? i was just stating man.....research and DO IT.
_Jake D
_Jake D
