CEL Issues Resolved
Old May 11, 2006 | 05:34 PM
HMCK20's Avatar
FML
Default CEL Issues Resolved
Took the car to the dealer and they said it was running way too rich. So they called honda and they said to adjust the valves. They adjusted them, the tech said that not one was right they were all too tight/loose. So after that they started and ran it for a bit still too rich. He called honda again and they said to replace the injectors. Injectors replaced and problem solved. I was amazed at what a diff the adjustments made, the car drives way diff now.
'11 2.0T R-Spec Bathurst Black
AA M4, Glock 17 36, P22 Mil
Old May 11, 2006 | 05:49 PM
integraman89's Avatar
lost u already???
you bet, the rocker arms are what they adjusted, you can gain a bit of power if you adjust them open a litlle bit more, that way more air intake/exhaust can pass through the head, the only thing is you need to be carefull cuz if you adjust them too open... they can hit your piston.
