HP loss update
Well, originally I was wondering why the compression was low and the HP was far below what the motor should've been putting out. The motor siezed up a few weeks ago and has been sitting. I finally got it out to disassemble. Bronze flakes = rod bearings = crank must be out of spec now = need new b18c5 crank. The pistons are siezed meaning possible rebore of block + oversized pistons.
Pics of damage:
Pics of damage:
Basically I'm wondering what the suggestion is here now. I spoke to Neal and he's gonna take it apart and look for me. I'd like to keep the R bottom end (bling factor y0). I have a few options now since crank and pistons have to be replaced. I was looking at a Crower stroker kit (crank, rods, pistons, rings) but Neal advised against it. Any ideas? N/A is the game. 210-215 whp is goal.
damn what is up with cranks lately
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
Originally Posted by 99B16Si
put an ls crank in there if you cant find an ITR
OEM vs. aftermarket internals are a personal preference tho
goodluck with your decision
more stroke.
Gracie Barra Clearwater
Originally Posted by sxecrow
It will never rev as high as the c5, though, correct?
You can rev an ls 89mm stroke to the limits of your powerband i.e. 8900 rpms etc. You simply need the proper rod bolts on ls rods to do so.
If you decide to run oem pistons again, you will also have to remove 1mm of space from each side of the piston to run ls rods.
IMO, 89mm stroke is going to be fine for you.
