Car wont run
Originally Posted by ekhatchboy
check your wiring. did you mix the map sensor and tps up? try that. this happened to my car
Originally Posted by NeEd4SpEeD08
yeah it does sound like compression, you might have fried a ring or bent a valve
this may sound stupid but check the ground cable on the valve cover... i did a swap and went crazy trying to figure out why it wouldn't start up (for about a week) yeah it was the ground. sometimes the problem can be something very easy that you overlooked because you were thinking it was something way more technical.... start off with the most simple things you can think of, then work your way to the hard ones...g/l
Is this the head off your overheated engine? maybe its warped bad and wont seal causing no compression.
1998 crv daily beater
its a whole cx motor with my dx tranny and such and a brand new headgasket.im putting a timing belt on today and hopefully that will work.its just funny to me how you chime in on such the occasion.thanks for your input though!
