Jumps Between 1-2k Rpms For No Reson
Old Apr 13, 2006 | 01:34 PM
aj187's Avatar
FORE:exalt
Yes, take it off and clean it with brake cleaner. And syncromesh is good, i have heard of it working. If it doesn't oh well its not that exspensive .
Old Apr 13, 2006 | 01:40 PM
JDMBlackGSR's Avatar
Gators Bitches!
could also be a vacuum leak, thats what mine was.
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
Old Apr 13, 2006 | 03:56 PM
VOD's Avatar
VOD
Field Rep
u can get a used iacv for about $30 and def check your vaccum lines...my car was doing the same thing..droping about 500 rpm...replaced both now she runs good
Old Apr 14, 2006 | 07:20 AM
sprayedtegra's Avatar
Fucking HONDA enthusiast
I would try the syncromesh! I had a nasty 3rd gear grind, and now its totally gone! It's worth a try for sure!
Old Apr 18, 2006 | 05:52 AM
TurboJdmEk's Avatar
is on blocks...
thanks alot i will try cleaning my iacv its on the back of my intake manifole correct?
its coming...
Old Apr 18, 2006 | 06:06 AM
InYaFace's Avatar
Is Pure Evil
Originally Posted by juiced2ndgenteg
IACV is not working properly. $425 to fix the tranny($300 for 1-2 sleeve set, $125 labor) you would just have to bring me the tranny.
or you could buy my Jdm B16 Cable tranny with 30k miles on it with brand new internals and a Quaife LSD for $650 which is a steal! lmk....
Old Apr 18, 2006 | 10:54 AM
  #17 (permalink)
95GS-r's Avatar
Night Rider
Here's a simple test: take off ur IACv and plug the hole with ur finger or a piece of paper. If it stops fluctuating, it's ur valve. If it keeps doing it, u prob got a vacuum leak. I have a valve for sale from a B18. If ur IAC looks like the one below, and make sure it looks just like it, pm me and i'll sell u mine.
Old Apr 19, 2006 | 11:26 AM
  #18 (permalink)
integraman89's Avatar
lost u already???
well actually if the car kinda acts like its "breathing" up then down up then down constantly, then it would be your tps (throttle position sensor)... try unplugging this and see if it stops acting up, i am almost certain this would be your problem
Old Apr 20, 2006 | 04:35 AM
  #19 (permalink)
#1cb7's Avatar
It is the IACV I seen the car run not only it is slow but it is a pos
Old Apr 20, 2006 | 05:25 AM
  #20 (permalink)
TurboJdmEk's Avatar
is on blocks...
david buy a car slow ass and invest in a dohc so you can break the 100 hp mark ass face keep talking shit and ill walk your sohc in my dohc
its coming...
