No check engine light??? help please
Check for power at the ecu power and check grounds at the ecu especially the logic grounds. Is the main harness ground hooked up at the thermostat. Check the ground strap for the tranny also.
Gracie Barra Clearwater
Thanks for all your help guys, I found the problem. It seems a rodent of some sort got in the wiring and chewed up a few key wires. After rewiring the chewed harness, the car started right up.
