H22 Dyno Numbers
Old Apr 10, 2006 | 09:28 PM
  #21 (permalink)
indeed's Avatar
tranny breaker
Originally Posted by accord95
the tune was great, something was wrong with the motor. after i pulled it out of the JDM front clip and had it put in, it only put down 159whp stock. then all the additional work only gave me 170whp.
stock computer stock cams sounds about right...
Old Apr 11, 2006 | 06:29 AM
  #22 (permalink)
accord95's Avatar
USMC
159 was with stock cams and ecu. 170 was with skunk2 stage 2 cams, and ecu with chrome pro.
TR happily married crew-member #2
___________________
Originally Posted by Troux
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Old Apr 11, 2006 | 06:50 AM
  #23 (permalink)
1BADP71's Avatar
E & I Certified
damn . i put down more then that .. when i was stock with a small exhaust
Old Apr 11, 2006 | 07:37 AM
  #24 (permalink)
indeed's Avatar
tranny breaker
Skunk Cams explains alot. The overlap on the h22 is to great and you loose all of your power. You need really high compression like 11.5:1 or higher to run those. Or boost.
Old Apr 11, 2006 | 07:41 AM
  #25 (permalink)
Cold_Beer's Avatar
Rockin' 4 more Cylinders
Originally Posted by qbanjr9
my jdm h22 lude dynno at 171whp $162trq and it was everything stock not even an intake... and then in my hatch it dynno at 500+whp with a big turbo and some intarnals done
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Apr 11, 2006 | 10:07 AM
  #26 (permalink)
accord95's Avatar
USMC
i did have 11.5:1 compression ratio, i think the japanees guy who owned it before me ragged it to shit. it already a few performance parts on it when i got the JDM front clip.
___________________
Old Apr 12, 2006 | 07:39 PM
  #27 (permalink)
pimpingreen13's Avatar
does anybody know what axles you run if you drop it in a EG? I just ordered my hasport mounts so I need to know so i can get them before the mounts come in. Thanks
Old Apr 13, 2006 | 07:45 AM
  #28 (permalink)
juiced2ndgenteg's Avatar
Originally Posted by pimpingreen13
Anybody on here running NA H22? What numbers did you put down? Im trying to get a feel of what i will be puttin down with I/H/E 11:1 pistons, Skunk2 Intake Manifold, thin head gasket, Fidanza light flywheel, Pro clutch stage 3 clutch and Ferrea Valves, Retainers, and Dual valve springs. If anybody has a similiar setup just post your numbers. thanks
Less than a stock LS with a t3 on it.
Old Apr 18, 2006 | 08:29 PM
  #29 (permalink)
Just waiting on the axles to do the swap. Motor mounts are on the way, pistons on the way and i just got the ecu's this weekend. Cant wait to get it running.
