Help tapping my block for oil lines
Old Apr 5, 2006 | 03:54 AM
sleeping95b18b1's Avatar
Default Help tapping my block for oil lines
i'm gonna go ahead ad install my turbo myself, i just don't know where or how to tap the block for the oil lines, i need to know where and how(need pics to go with it, i'm a visual person) thanks
Old Apr 5, 2006 | 05:01 AM
99B16Si's Avatar
you dont need to "tap" anything.
the oil feed line will come from the oil pressure sending unit port in the back of the block(it has 1/8th npt threads)
the return line will go down to the oil pan and there are many ways to do this. do a little research on honda-tech.com on "oil return lines" and youll have a better idea
Old Apr 5, 2006 | 05:34 AM
weeper's Avatar
if u aint boosten go home
its very easy i can do it i did it on all my cars if you want call me i can give you a hand 8139665018 thats if your intersted !!!!!
Like us on facebook
Old Apr 6, 2006 | 01:05 AM
Jap's Avatar
Jap
VTEC Out
The block actally has BSPT threads . Get a BSPT to NPT adapter T with a 1/8th NPT to -3 an fitting and run your feed line to your turbo
Get under the bottom of the car behind the block
Take this off
thread Oil Pressure sender into T
Now tighten it back in , but try not to over tighten it as the BSPT threads are semi-fragile
It should look like this
Now run it to your turbo oil feed spot and tighten
It should look something like this
You can buy the oil line kit here
Hope this helps
Hondata saves lives
Old Apr 6, 2006 | 03:26 AM
Default deleted
thanks man very helpfull,
