HELP!! Car wont start!!
Old Apr 4, 2006 | 08:54 AM
Presidential_Detail's Avatar
aka The Twanksta!
Originally Posted by CECORREL
If its a stock fuel pump, its going to be hard to hear it!!!
You can try and check the starter wire? I dunno... Let us know if its able to be push started!!! If so it will narrow a few things down...
I can hear mine
Visit Our Site - Presidential Automotive Detailing
Authorized CQuartz FINEST Installer
Old Apr 4, 2006 | 09:00 AM
knifefight's Avatar
Thank You! +1
I beat on Relient K's all day
Xbox w/27 Games For Sale
http://www.tampaforums.com/forums/el...ml#post2890808
PSP For Sale
http://www.tampaforums.com/forums/el...ml#post2889890
Old Apr 4, 2006 | 09:56 AM
If starter tests Ok, but won't turn in the car, sounds like the wiring
on the way from start switch to starter,....something keeping electricity from getting there.-Bob
Originally Posted by civicSi07
I have my 92 si hatch, and i used it this past thursday, and went to turn it on saturday morning... and nothing. all i get is the electric running thru it.
so i got the battery tested and it was fine, then sunday i pulled out the starter tested, and it was fine. took it home, neighbor got it all apart and put it back together. got it re-tested and it was still fine.
then today (monday), i pulled the alternator out and got it tested, and it was fine.
so i bought a new distributor cap and rotor and will try that tomorrow.
any ideas on what the problem is? the engine wont even try and turn over.
please help me out.
Old Apr 5, 2006 | 06:19 AM
civicSi07's Avatar
my alarm does work; we checked to see if power was running to the starter, and there was; all fuses are fine. i am thinking of replacing the clutch switch first.
i'll keep giving updates.
Old Apr 5, 2006 | 06:41 AM
knifefight's Avatar
hey dont replace the switch test it first, take the harness off the switch then take a paper clip and put one end in each one of the holes then try it, not positive if its a necessity but i dont have one... i just make sure my car is in neutral when i start it and im pro
PSP For Sale
Old Apr 5, 2006 | 08:52 AM
civicSi07's Avatar
so if it is the switch, this would tell me that? is this what you did.. the paper clip thing?
Old Apr 5, 2006 | 08:54 AM
  #17 (permalink)
civicSi07's Avatar
also... i was wondering if the ecu is throwing codes when i try to turn the car on?
would i have to take the cover off the ecu to see led's?
Old Apr 5, 2006 | 09:18 AM
  #18 (permalink)
knifefight's Avatar
i didnt do the paper clip thing but that was only cause a wire was ripped out of the harness when i bought the car so i just ripped out the other stripped the wires put them together and the car started right up
PSP For Sale
Old Apr 6, 2006 | 06:10 PM
  #19 (permalink)
civicSi07's Avatar
ok so well i got it to start today by popping the clutch with 2 ppl pushin. the alternator belt is pretty loose, and i need to tighten it. also the alternator sparks where the screw comes out of it for the ground and just does it more as i rev it higher.
so im thinking of gettin the belt tightened, and trying to find a better ground on the alternator housing.
i was also thinking of maybe why the car doesnt start by itself is because of a bad ignition switch? i will probably replace that on saturday.
i was just giving a new update on whats going on.
Old Apr 6, 2006 | 10:13 PM
  #20 (permalink)
aka The Twanksta!
I dont think thats a good thing???
