please help im making big purchase need advice!!!
Old Apr 1, 2006 | 12:18 PM
Kouki Crisp's Avatar
Default please help im making big purchase need advice!!!
will this fit in my eg civic 93 dx check the link look at what it comes with and tell me am i getting all i need for the swap thankyou
http://www.japaneseengineimport.com/...da/B16A-G1.htm
Old Apr 1, 2006 | 12:23 PM
TampaTraps's Avatar
get big or die trying!!
that motor that you picked is a cable tranny pre obd b16, your car a 1992-1995 civic(eg), is a hydro tranny pbd-1 car, so this is the motor you need http://www.japaneseengineimport.com/...da/B16A-G2.htm . from what i rad on the site they don't include axles, so you will need those. along with the rear motor mounts from a integra94+teg, the throttle cable from a 94+teg. and shift linkage from a 94+ teg
that's president hussein obama to you :gordy:
Old Apr 1, 2006 | 02:55 PM
is that all... im prolly lookin at close to 3 g's i have someone to do a swap for 400$ so its kinda tyte please leave me some feedback and let me know if this is all i need thanks
Old Apr 1, 2006 | 04:11 PM
kender's Avatar
gadget man
it also lists 160hp on 10.4:1 comp. The obd0 pr3 b16 is 10.2:1 at 160hp, the 10.4:1 b16 is obd1 and 170hp. You would need mounts, shift linkage, axles, and either an obd1-obd0 conversion harness ( which would be a totally ass backwards way to go) or swap the dizzy, ecu and o2 sensor for an obd1 setup (p28 ecu). should only run about $250 at the most. $100-$125 for ecu, $80 for dizzy, and $50 for o2. the conversion harness would run about $100-$150. If you can get some good deals here on tr you could easily get the obd1 stuff for less than $175. So for the few $$ more you can make the motor match your car and have the obd1 which is a better ecu to have for tuning. the mounts if you go with hasport can be bought for about $350. axles are $120 from autozone, shift linkage $50-$150 (depending on where you get it). so for less than $750 plus the $1400 motor you'll be set for the install. Depending on the condition of the parts on the motor after shipping and what nuts and bolts you get with the other parts ( if you buy used) you may have to spend a little bit on odds and ends but I wouldn't imagine more than $100 for that stuff. For $2250 you should be ready for install, if you can be patient and dig around for a better deal you could probably get the obd1 b16 for the same price, or maybe less. I bought a sirII motor for $700 (which included the ecu) and a hydro tranny can be bought for $500 (sometimes less). It's definately do able on your budget.
U.S.S.A Crew Member #001
Old Apr 1, 2006 | 04:50 PM
DavidEK's Avatar
drives a truck
just save a little more and get a b18c1, well worth the extra money spent. A b16 is pretty weak IMO. Just my .2
Old Apr 1, 2006 | 05:50 PM
jlude90's Avatar
aspiring luder
http://hmotorsonline.com/shop/sc2000...age&item=30002
and read the asterisked part at the bottom
also i've only heard that they are a great place to get engines, its where i'm going, and where friends have gone, just another place to look
Old Apr 2, 2006 | 06:54 AM
TampaTraps's Avatar
again wrong motor for a eg.
http://hmotorsonline.com/shop/sc2000...age&item=30005 this is everything you will need.
Old Apr 2, 2006 | 11:23 AM
indeed's Avatar
tranny breaker
HMO sells clean motors. I have been purchasing from them for about six years now and have only had 1 problem. It was resolved immedately. BTW spend the extra 300 bucks and get the lsd. good luck
Old Apr 3, 2006 | 12:08 PM
guys thanks SO much for your help youve all been great im currently saving the rest of the money for this im down to do this swap it needs to be done my confidense in doing this is like 110% lol thanks for all your input and thankjs for letting me know i can rely on TR ------------ MUCH LOVE ^_^ -Sean
Old Apr 3, 2006 | 02:48 PM
Cr33pIn'_UnYa's Avatar
Fuck All That Shit Buy My Rebuilt B16
