Iacv
I read somewhere that it is possible to bypass the IACV, I know thats the problem with my car. Cant get to it though tried liquid wrench bolts stuck. It was doing the surging idle until i said screw it throw a code and unplugged the harness for it. ive noticed my car does warm up faster but it doesnt over heat not even on long trips. i also read somewhere that it would be cheaper just to pull a whole manifold. if i do so what would be a good one to bolt up to my b7 or should i just get the same one?
I beat on Relient K's all day
Xbox w/27 Games For Sale
http://www.tampaforums.com/forums/el...ml#post2890808
PSP For Sale
http://www.tampaforums.com/forums/el...ml#post2889890
PSP For Sale
i think i saw a bypass on 92lude.com to give u some ideas...i have some of the same issues...a new iacv was going for like $200...instead of that i just got a used intake manifold from another tr member for $50..g/l with your issues
sounds like it isnt the iacv, but actually the warm idle control valve. when you remove your intake, you'll see 2 holes in the throttle body. the one towards the firewall is the iacv, the towards front of car is warm idle control valve. just take some double sided tape of something and kinda clog up the hole.
goodluck
goodluck
I <3 RooR!!!!!!
I <3 RooR!!!!!!
Thanks for the help. Ive got a b7 so the holes are one on top of the other inside the throttle body, and if i cover the bottom hole the idle drops. But its odd i hooked the sensor back up today i think the car was already warm though cause it didnt surge at all... but ill def try what you guys said
PSP For Sale
PSP For Sale
http://www.92lude.com/idle_air_control_bypass_mod.htm heres the link to that one site you were talking about im gonna try that today cause it did it again this morning...
PSP For Sale
PSP For Sale
