Does any one want to build my h22 motor with me!
Old Mar 31, 2006 | 04:42 AM
98whiteprelude's Avatar
Default Does any one want to build my h22 motor with me!
Does any one here know anything about The h22 motor? Im going all out in a couple of weeks and need help! I got a 98 prelude all stock.. I want to do cams, cam gears, Rods,Piston, Air intake Im going to fully build it. I also want to convert my car from automatic to a built 5 speed with a stage 3 clutch and all.....
I will compensate you for all the work... Ill even put a sticker of your name or your company on my car if you want... LMK
Old Mar 31, 2006 | 05:49 AM
99B16Si's Avatar
ckeck the post listing all the shops in the area, its stickied to the top of this forum
Old Mar 31, 2006 | 06:17 AM
B18C5-EG's Avatar
Cold_Beer on here is a big fan of H-Series ask him
Old Mar 31, 2006 | 07:06 AM
indeed's Avatar
tranny breaker
you do know that this block MUST be sleeved to run forged pistions right? PM me i can build this motor for you.
Old Mar 31, 2006 | 02:38 PM
95gainfla's Avatar
smokes weed...everyday.
you OFFICIALLY know NOTHING about H-series engines.
mahle makes a forged piston specifically for the H and it doesn't require sleeves.
I <3 RooR!!!!!!
Old Mar 31, 2006 | 04:18 PM
MacGruber's Avatar
MaDe Of MoNeY
I also believe cp has special coated pistons or something of that sort that will work with the frm sleaves
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Old Mar 31, 2006 | 08:14 PM
accord95's Avatar
USMC
wiesco also makes a coated piston for the H-series that doesnt require sleeves.
you could also put JDM H22 type-s pistons in it and bump up the compression.
TR happily married crew-member #2
___________________
Originally Posted by Troux
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Old Mar 31, 2006 | 09:01 PM
lowoctane's Avatar
Professional Dumbass
if your looking for pistons and rods. *BOTH BRAND NEW* i have a set of Crower H billet rods, and CP pistons 9.0comp w/rings for sale. only 600!!!!! mad cheap, im taking the loss.!
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
Old Apr 1, 2006 | 02:36 AM
indeed's Avatar
tranny breaker
Really? because i have run these so called coated pistions and they have failed... So let me rephrase so you can understand....The only way you will make power reliably, besides using a "stock honda" pistion to raise compression is to sleeve the motor.
Dont get me wrong the h22 is a bad ass motor, tranny sucks ass but the motor is really strong. In JDM compression all motor setup a beast of a motor can be had. JE and CP dont even advertise this "special coating". Mahle is the only one that does and yes they make great pistions. Have you used them in H series sleeves? I have. Just like any other honda i would much rather sleeve and match a forged pistion with known reliable parts....
Btw thew h22 sleeve is made from FRM or fiber reinforced metal. This is also used in the NSX.
Making FRM sleeves goes something like this: First a fiber-based material in the shape of the cylinder sleeve is inserted into the die of the cylinder block. Liquid aluminum is then poured into the die and fuses with the fiber sleeves. Once the block is ready for it, the cylinder walls are machined to the desired bore dimension, leaving only 0.5mm of thickness to the fiber sleeves that cover the cylinder walls.
With the reinforcement the sleeves generate lower friction than traditional iron liners, which translates to improved revolutions, power and reduced wear. In addition the thinner fiber sleeves fortify the block, allowing the distance between adjacent bores to be reduced while maintaining strength and rigidity. There are drawbacks, however. It can be argued that because they are so thin the sleeves were not designed for too much boost pressure, which limits the potential of the stock engine and poses a challenge for us.
Overboring for more displacement is also out of the question since the sleeves are so lean. Even if you machine-off enough material to avoid breaking through to a water jacket, you still have to deal with the softer untreated metal under the fiber layer. For these reasons it is recommended that H22 sleeves never be bored or honed, always replaced.
Old Apr 1, 2006 | 08:02 AM
jl8383's Avatar
Not to sure but doesnt the newer H22a4 have steel sleeves.
