Does any one want to build my h22 motor with me!
http://www.honda-tech.com/zerothread?id=121765%22 this topic has been on honda-tech for a while. check it out...
No H-series have steel sleeves, I've heard of others running coated CP/Weisco pistons and still having them fail, Mahle is the only company I've seen that clearly states you do not have to sleeve, there was even a build in HondaTuning where they toss them in an H22. OEM Type-S come in .25 os but that's as far as I'd go with stock sleeves. There are several members on here that could assemble the motor for you or if you're the DIY type, pick-up a Helm's manual for your 98 Prelude it covers tear-down and re-build, very useful book, should be your bible, lol.
-Mike
-Mike
http://www.myspace.com/jdmmike02
2000 Ford Expedition Eddie Bauer
2004 Kawasaki ZX6R - SOLD
Originally Posted by 92jdmda
For these reasons it is recommended that H22 sleeves never be bored or honed, always replaced.
Really? because i have run these so called coated pistions and they have failed... So let me rephrase so you can understand....The only way you will make power reliably, besides using a "stock honda" pistion to raise compression is to sleeve the motor.
did you use MAHLE? if not, i dont really care. because i said mahle.
and IF they failed...oh well. I'm sure people running B series with cp's/srps/wisecos/je's/whatever forged pistons have had them fail too...it doesnt mean EVERY set will fail, or every engine, or whatever.
I <3 RooR!!!!!!
I <3 RooR!!!!!!
I personally won't build H motors if they are not sleeved. There is a very certain way to prep frm sleeves and most machine shops don't know how to do it correctly. As a builder it isn't worth the risk of having a failure and it being blamed on you.
Gracie Barra Clearwater
well see as soon as i get a clutch and my flywheel from chavez how reliable a rebored .25 and honed H22 with type s pistons is.
im in the final stages of getting my motor back together.
also need a h22 timing belt oem if anyone has one they wanna sell.
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
TR H2B crew #2
Originally Posted by 98whiteprelude
Does any one here know anything about The h22 motor? Im going all out in a couple of weeks and need help! I got a 98 prelude all stock.. I want to do cams, cam gears, Rods,Piston, Air intake Im going to fully build it. I also want to convert my car from automatic to a built 5 speed with a stage 3 clutch and all.....
I will compensate you for all the work... Ill even put a sticker of your name or your company on my car if you want... LMK
it dont matter what need sleeves and what dont. he said he was going all out / fully built. that would include sleeve....
.but yea. my 2cents, any high comp/boost on h-motors would need sleeves.
