what is honda's reccomendation?
just installed a new oil pressure gauge on a mostly stock d16y7. what should it be reading? and what would cause it to be high? low? (besides the obvious of no oil) also what oil temperature range is the norm? any help will be greatly appreciated.
I AM THE MADMAN
I AM THE MADMAN
Mine is like 80 when i am on the gas, and drops to like 30 when it is hot. It is also going to matter what oil you use and what wight. As the oil drops the psi will drop.
Cburke.industries.
Custom suspension bars, metal fabrication.
Cburke.industries.
min goes up to 90-95 when i am on the gas and is up like 75-80 around 3000 rpm... manual says 50 at 3000. what would cause high oil pressure.
I AM THE MADMAN
I AM THE MADMAN
