highest tire width on a crx
im wanting to get as big as i can get without rubbing. heres a pic of my 205s on with how low i have the car. do you think i can get 215s? 225s? there going to be mounted on 15 in slips.
:FASQUAD:
:FASQUAD:
yeah i run 205's on my gsr's and they dont rub, i dont think it would hurt to step up a size and give it a shot, on my car it looks aas if i could fit wider, worse case senario... they rub, im sure if you take you car to a tire place they may be able to help you out on this, heck they may even put one on you car to see if it rubs... its worth a try...good luck
Looks close right now.
First, I would check to see how much travel the susp has when it hits a bump. Then I would go with a lower profile tire or smaller rim to be sure
the tire won't touch when the susp is at it's highest point.
I have a technique to measure this, and once you know, then you're
set........until you go lower...
We can also measure the clearance while turning. Call me -Bob
