civic runs like shit
Old Mar 28, 2006 | 06:45 PM
mustangtye's Avatar
Default check engine code 43. bad fuel system
I washed my car tonight and and i had just put on a air filter my cold air intake. i drove out fine and everything ran good for a little bit and my car deffinatly wasn't smokeing and the after letting it idle for 5 min. i drove off from a stop and my car just boggs out so i was thinking i might have sucked in some water. still no smoke. now my car doens't go past 4000 rpm's and it takes forever to even get to that. i changed my oil and cleaned everything i could. did i maybe bend a valve or something. anybody know whats up? gimme some ideas.
<img src=https://www.tamparacing.com/forums/signaturepics/sigpic27077_1.gif alt= class=post_inline_image loading=lazy />
Old Mar 28, 2006 | 06:55 PM
aj187's Avatar
FORE:exalt
How are your spark plug wires?
Old Mar 28, 2006 | 06:56 PM
SmokinS13SR20's Avatar
That ginger...
Disconnect the forward most fuse in the under-hood fuse box for a minute then try it, your ecu might be in limp mode.
Old Mar 28, 2006 | 07:02 PM
mustangtye's Avatar
checked the plugs, plugs are fine and i changed them not long ago.
Old Mar 28, 2006 | 07:04 PM
aj187's Avatar
FORE:exalt
Did you try pulling the ecu fuse? Is it throwing any codes?
Old Mar 28, 2006 | 07:08 PM
mustangtye's Avatar
na haven't checked that yet, but the check engine light isn't one either.
Old Mar 28, 2006 | 07:11 PM
aj187's Avatar
FORE:exalt
How about the fuel filter and fuel pump how are they?
Old Mar 29, 2006 | 04:03 AM
mustangtye's Avatar
actaully it might be the fuel pump. i got a check engine light today and the code read that i have a malfunctioning fuel system. code 43. so maybe its nothing to do with sucking in water from the post before. so it runs like shit, ideles rough and i have bad gas milage. any more ideas
Old Mar 29, 2006 | 11:31 AM
aj187's Avatar
FORE:exalt
Fuel pressure regulator, and fuel pressure are also check for vaccum leaks around the engine.
Old Mar 29, 2006 | 12:01 PM
DD.'s Avatar
DD.
Administrator
so if its code 43, its deff. your fuel. sooo...check all of your fuel stuff. injectors,regulator,pump,fuel lines...etc.
Also...do you smell any fuel?
