civic runs like shit
Originally Posted by HonCiv93
so if its code 43, its deff. your fuel. sooo...check all of your fuel stuff. injectors,regulator,pump,fuel lines...etc.
Also...do you smell any fuel?
As for the bad performance, When checking the wires, Did you happen to see any water/moisture on the bottom of the wire or a little puddle in the spark plug hole?
Did you wash your engine bay when you washed rest of the car and installed the intake?
i didn't wash the engine. but i think that it just happened to be wen i washed my car i just happened to have this problem at the same time. so i'm thinkin i might have a clog in the line or a bad injector. the car bucks really bad. now it only goes up to about 2600 rpms. and i also over heated at a point and need to put water in the radiator. so i have no fuckin clue what it could exactly be. but i guess i'll just have to start trying things.
