EF B series swap question
ya,i would buy mounts rather than go threw all the work of getting it all straight.Dont think that i didnt have a hard time getting my b16 straight.Shit,that was almost 6 years ago and i got lucky.It was fine as long as i used OEM axles.I would go threw napa axles in 2 hours no bul shit.Oem's would last a year+.It never pulled and the motor sat straight as hell but napa axles just would not work.The pic of the rex w/ the b16 is still in my gallery.take it from me ,man get mounts and save alot of time..i see them for 100 on ebay all day....
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
as moving it , someone i know has cheap mounts and they rubbed the torsion(sp) bars with the crankpulley
IF YOU NEED WORK DONE CALL THE NUMBER BELOW
727-916-0361 Matt
AIM- B1ackcracker
I have used cheap ebay mount for peaple many times.they have always worked great for me..the motor is stiffer with cheap mounts thats about it..
727-916-0361 Matt
AIM- B1ackcracker
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
yea hopefully if i can get my ecu sold ill have money to get a set of used mounts i found, thanks for all the help and advice guys
Is finally 4dr pimpin again
Rollings not racing either go from a dig or go home
Originally Posted by integra
cheap mounts are just as bad as moving it , someone i know has cheap mounts and they rubbed the torsion(sp) bars with the crankpulley
i used hasports and my B20 rubbed the torsion bar on the crank pulley. It's all in how low the car is and what crank pulley.
Cheap mounts work just as good as expensive swap mounts.
RIP Robert Kolp aka 00ek 4/07
_Jake D
_Jake D
Well IF your going to move the mounts, you'll notice on the mounts they have little impressions on them where they are welded onto the fraime. You need to drill out those holes with a good size bit, and then reweld back in those holes. Pretty simple concept, and if you need any pics you can always look at the k20 into a crx where you must take off the pass mount. you can use that as an illustration guide to it. -Ben
