head removal
Old Mar 21, 2006 | 11:39 AM
integraman89's Avatar
lost u already???
how old is the head gasket, if it hasnt been changed in a REAL long time, it will stick to the block "like glue", the way i do is i leave the intake manifold on make sure ALL the bolts and brackets are off then push down and pull up on the mani, "wiggle it free" that way there will be no prying. everytime i have done it this way it was effective. and i have done this many many times.
Old Mar 21, 2006 | 06:38 PM
SmokinS13SR20's Avatar
That ginger...
I to did the same htign but i had to apply most of my body weight to do this (240) on a 90 crx, to put that sucker off good luck. If you arent to far i could come and help
Old Mar 21, 2006 | 06:43 PM
b16a2pwr's Avatar
ALLJDM
Thumbs up
that's what I love about TR, the willingness to help others!!!
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
Old Mar 22, 2006 | 02:44 AM
JoKiE crx4294's Avatar
popeye built!
i live in camden citrus park onthe corner of sheldonand waters if any body wants to come and try to get the damn thing off
Can't spell strength without tren
AAS...It's whats for dinner
Old Mar 23, 2006 | 02:39 AM
popeye built!
still cant get the head off. this thing is stuck on there. ive tryed to but abreaker bar in the exaust port and break it loose but nothing
Old Mar 23, 2006 | 06:01 AM
Zxc4's Avatar
Hmm, you may be msising a bolt somewhere, double check. If you are sure you have all of the necessary bolts out, you could try taking a block of wood and putting on each of the 4 sides of the head and gently hitting it with a hammer to try to get it to break loose. Just a thought.
Old Mar 23, 2006 | 09:35 AM
  #17 (permalink)
popeye built!
trust me all 10 head bolts are out and the mani is off to
Old Mar 24, 2006 | 02:32 PM
  #18 (permalink)
civicized's Avatar
did you take the power steering bracket off. Can't recall for sure on that engine, but think it joins the block and head. Also, there should be tabs on the corners of the head for inserting a flat screwdriver to pry the head up. If you get a blade in those and it still won't budge, you have something still bolted somewhere. Needless to say if you blew your engine it could be any of a number of things, obviously a valve could be sticking through a piston or Lord knows what...
Old Mar 25, 2006 | 06:55 AM
  #19 (permalink)
Blown99civicSi's Avatar
EFI Tech/Tuner
Wow, you are scaring me with all this prying, that head and block is aluminum (SOFT STUFF!!!!) dont pry!! you may have already messed the head up and nicks or scars on the heads surface or in the exaust ports will hinder performance as well as cause leaks.. The head should pop off, Do this find were the head meets the block, follow that from the fromt to the back, looking for brackets that connect the head to the block, like power steering brackets and such, Once you do that reinstall the intake manifold tighten the bolts!!! and use the rocking idea as stated above this will give you all the leverage you should need. If it does not come off STOP!!! either the motor was over heated, causing the gasket to seal the block and head together or you are still missing something.. See if you can get some help(outsiders) Its a good idea sometimes to get a fresh set of hands in there with a clear head, that may find the problem, If not take a step back and just look for a while and double check things 2-3 times.. Nothing will come by getting ed off or mad, other than broken parts.. G/L.
I cans stress enough the prying needs to stop or start looking for a new head/block.. or saving money for some serious machine work!!
Modified Racing
Street Tuning & Dyno Tuning the greater east coast area for over 10 years and running!
AEM/HONDATA/MOTEC/FAST/DEFI & More
EFI-101 Certified
(941)628-4988
