need help figuring out what the hells wrong
i checked the plugs, tips are black, motor is runnin rich, i put another set of stock injectors in and the prob came almost instant, go to give it throttle and the motors wont rev past 1k, sounds like boggin plus a slight hint of rev limiter?
What kinda ecu?
If everything mechanical is ok like your fuel pressure and injectors, then it could be an input to the ecu. Like a MAP sensor.
Dumb question, but have you verified cam timing?
Off cam timing will reduce manifold vacuum giving the ecu a false sense of a heavy pedal and thus give it gas cause it "thinks" its under load...just an idea.
Now residing in Atlanta.....
Originally Posted by Honda_Quaalude86
ps... the rev limmeter thing makes me lean towords a Throtle position sensor
i am going to buy a fuel pressure gauge and install my fpr. im going to see what my fuel pressure is at! ive narrowed to a fuel or ignition prob more towards the fuel problem tho! will keep updated!
i think you should stop boosting on stock injectors....
I <3 RooR!!!!!!
I <3 RooR!!!!!!
Guest
Posts: n/a
Maybe a mass airflow sensor..or somthing of that sort...does it run rich or lean? and...and does it havea skip? ide try spark plugs and a basic tune up...and defanetly a fuel filter bro...and if thats not it i know that sometimes the filtter on the actual fuel pump gets gunked all up...maybe drop the tank and take a look at it...the filter for the fuel pump pick up is like 7 bucks...and the fuel filters like 10...so try the cheap stuff first...then maybe a mass airflow sensor..or a o2 or shit like that...
