need help figuring out what the hells wrong
Originally Posted by Keith
you can take an o2 out of the car completely and it will still run properly... that is why i dont think it is the o2...
Now residing in Atlanta.....
The O2 will give you bad fuel economy, not make the car run bad. It also would through a check engine light if it was bad.
Change the filter; then just for shits clean the injectors. If you have an extra $40 then get an injector grommet kit from discount. Makes sure you are getting a good tight seal on the injectors.
Cburke.industries.
Custom suspension bars, metal fabrication.
Cburke.industries.
as far as the o2 i dont have one, when i got muh d/p made i didnt get a o2 bung welded in /i will tho, but i am going to clean the injectors tday and when i order my ecu from phearable i can have john disable the o2. thanx so far everyone for the help, keep it comin!
Guest
Posts: n/a
you should have posted that it was turbo... that makes a big difference... you need some fucking tuning first off... then go from there...
I <3 RooR!!!!!!
I <3 RooR!!!!!!
Maybe a mass airflow sensor..or somthing of that sort...does it run rich or lean? and...and does it havea skip? ide try spark plugs and a basic tune up...and defanetly a fuel filter bro...and if thats not it i know that sometimes the filtter on the actual fuel pump gets gunked all up...maybe drop the tank and take a look at it...the filter for the fuel pump pick up is like 7 bucks...and the fuel filters like 10...so try the cheap stuff first...then maybe a mass airflow sensor..or a o2 or shit like that...
My si in the making
My si in the making
