vafc
Old Mar 14, 2006 | 12:34 PM
CBURKE's Avatar
Has to many projects
Default vafc
I need to know where on the VAFC do I adjust the A/F when I am at idle. My A/F gauge stays peged out on rich until I get moving and there is no fluctuating at all. I asked this on H-T and really go no response. Thanks if you can help.
Cburke.industries.
Custom suspension bars, metal fabrication.
Old Mar 15, 2006 | 06:28 PM
mtber's Avatar
I am guessing you are using your autometer a/f guage to check your a/f ratio ?
You must use a wideband oxygen sensor to determin true a/f ratio.
Without a wideband you are just guessing.
Old Mar 15, 2006 | 06:41 PM
Obviousreasons's Avatar
Welcome to Candy Mountain
A/F gauges are just for show unless you have a good one. Waste of money.
Need your Honda/Acura tuned? Ecu Chipped?
Http://www.Phearable.net
Need some Stereo/Security/Video Work Done? Almost Anything 12 Volt I can do. 12 Years Experience. Send a PM For Inquiries.....
Old Mar 16, 2006 | 04:37 AM
CBURKE's Avatar
I see, so they have no use at all? I understand the wide band is the way to go, but even if my Autometer A/F gauge does not give good readings it should still fluctuat and give me something instead of just sitting on the last green every time I stop. I am at 40psi and I just think it has somthing to do with the VAFC. I wish I could just take it off, but I have know idea what the Hondata/Spoon ECU will do.
Cburke.industries.
Old Mar 16, 2006 | 05:54 AM
CBURKE's Avatar
I just got a new O2 just for the reason I thought it was bad. I really don't know what I am doing as far as the VAFC but if I just have MTBER do it then what did I learn? I am going to have him to my work when I get the turbo and make sure all the bugs are out. So on that note how do I "pull some fuel out"? I just need to no what setting on the VAFC controls this? It can’t be the wid that is for wide open thr, and the narr is for normal driving. O well, hell I don't know.
Cburke.industries.
Old Mar 16, 2006 | 06:11 AM
60-1EK's Avatar
Engineer at the source
Originally Posted by Cronic
They are correct for the most part, you see a narrowband AF guage works on 1v while the wideband works on .1v.
The fact that you're showing straight green can mean a few things. Your O2 could be bad. You don't know what the hell you're doing.
Narrowband O2 sensors sweep 0-1V. Most WB O2 sensors have a 0-5V sweep. Widebands can interpret on a .1V through the 0-5V range. This is where the precision of the WB comes in. The standard narrowband O2 sensor is calibrated to sweep 0-1V from A/F ranges of approx. 13.75:1 to 15.25:1 A/F. If the A/F is below this range, the voltage sweep approaches 1V and thus your gauge reads rich. Your car could be at 13:1, which still sucks for a normal car's A/F at idle, but it isn't the end of the world. But in the same token, your car could be at 10:1 A/F and it too would show rich on your gauge.
If your A/F is above this range, the voltage sweep approaches 0V and thus your gauge reads lean. 15.5: or 20:1 A/F....it's going to read the same thing on your gauge.
The reason why those gauges sweep is because the A/F is bouncing out of the range of approx. 13.75:1 to 15.25:1 A/F. If it stayed in this range, it would not sweep like they do.
If you have no check engine light for your O2 sensor, don't replace it.
/End of break, back to helicopters.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Mar 16, 2006 | 06:39 AM
CBURKE's Avatar
So, do I need to ck the volts coming from the o2?
Cburke.industries.
