vafc
Old Mar 16, 2006 | 06:49 AM
60-1EK's Avatar
Engineer at the source
Originally Posted by CBURKE
So, do I need to ck the volts coming from the o2?
No. Read the manual on the VAFC. If you still don't understand it, have someone walk you through it so you can learn.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Mar 16, 2006 | 06:56 AM
CBURKE's Avatar
Has to many projects
I did read it, just really did not understand it. I'll read it again and give it a try. Thanks for the help.
Cburke.industries.
Custom suspension bars, metal fabrication.
Old Mar 16, 2006 | 10:26 AM
mtber's Avatar
If you seriously plan on using a narrowband, make sure your autometer guage is getting a CLEAN power & ground source along with a good signal source....
Old Mar 16, 2006 | 10:43 AM
integra's Avatar
90% grind 10% sleep
i can help you with the VAFC
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Mar 16, 2006 | 11:57 AM
CBURKE's Avatar
I am only planning on using the narrowband for now. When I get the turbo then that will be a diff story. Then I'll bring it to you. I just don't know a lot about the car because I bought it like this. So I am going through it and replacing things and fixing things to make it a good daily driver. I have had fuel problems ever sense I got the car.
Cburke.industries.
