little bit of white smoke :-0
Old Mar 9, 2006 | 08:19 AM
TIM TIM TIM's Avatar
could be worse
Default little bit of white smoke :-0
I went today to let the car run for a few and put some more gas in it.. well i popped the hood as i let it idle and notices a little bit of white smoke coming from the back side of the valve cover, its the back right. it seems to be coming out from between the valve cover and head and blowing down, but it may be from the head itself.. here is a pic of where... you cant see the smoke though, stupid phone..
aim:because tim said
Old Mar 9, 2006 | 08:50 AM
99B16Si's Avatar
its probably coming from the breather, and thats blow by which is not uncommon (within reason) for built motors with larger clearances but if you have a stock motor that usually indicates that your rings and/or ringlands are not in good shape
Old Mar 9, 2006 | 08:54 AM
could be worse
its not stock, srp pistons, eagle rods, ferrea valvtrain ect. i would not be suprised if its blow by, i plan to get the endyne breather set up soon. thanks
Old Mar 10, 2006 | 10:54 AM
could be worse
anyone else have opinions on what it could be? im not to sure its comming from the breather thing there.
Old Mar 10, 2006 | 11:19 PM
mtber's Avatar
Tim,
Get a leak down & compression test done. That motor has been through several owners before it was properly tuned.
Good Luck,
John Vega - Phearable.net
Old Mar 11, 2006 | 06:00 AM
could be worse
lovely
Old Mar 11, 2006 | 06:37 AM
94lsteg's Avatar
BOOST IS BETTER!
Originally Posted by TIM TIM TIM
lovely
+1 for what john said.
Old Mar 11, 2006 | 07:46 AM
could be worse
who can do one??? and how much??
Old Mar 11, 2006 | 08:00 AM
95gainfla's Avatar
smokes weed...everyday.
they sell compression testers are advanced autoparts. goodluck man.
I <3 RooR!!!!!!
Old Mar 11, 2006 | 08:12 AM
94lsteg's Avatar
BOOST IS BETTER!
its very easy to do a compression test.... call me if you need help Tim
