little bit of white smoke :-0
Old Mar 11, 2006 | 02:18 PM
TIM TIM TIM's Avatar
could be worse
i have a tester just havent done it, im not EXACTLY sure how, i have an idea but i would rather have someone that knows with me . i know its not difficult
aim:because tim said
Old Mar 11, 2006 | 03:42 PM
95gainfla's Avatar
smokes weed...everyday.
pretty sure you pull out the sparkplug, put in the tester, and crank it over?
I <3 RooR!!!!!!
Old Mar 11, 2006 | 08:58 PM
mtber's Avatar
http://www.c-speedracing.com/howto/c...t/comptest.php
http://www.c-speedracing.com/howto/l...n/leakdown.php
Old Mar 11, 2006 | 09:05 PM
94lsteg's Avatar
BOOST IS BETTER!
just kidding....FI injection fuse..
Old Mar 12, 2006 | 06:29 AM
could be worse
mtber you are THE MAN. thanks, your always helping me out
edit: is a leakdown test somthing I can attempt myself? I have a decent knowledge of motors and all, but I hate trying stuff for the first time with no one to supervise ... according to these directions it does not seem to hard, and im sure with the directions on the tester i can figure it out... with thtat said, where should i get a tester??
Old Mar 12, 2006 | 10:22 AM
mtber's Avatar
Tim,
You can't fuck it up. Unplug your ecu, take out your spark plugs, follow directions
I would recommend investing into a decent tested if you plan on working on cars every once and a while. Craftsman has a nice kit for $50.
Good Luck,
John Vega - Phearable.net
Old Mar 12, 2006 | 11:27 AM
  #17 (permalink)
could be worse
i WANT to learn, but everyone that has told me they would help is MIA when the time really comes... thanks alot, ill more then likely buy it tomorrow .. thanks again man!
Old Mar 26, 2006 | 05:15 PM
  #18 (permalink)
Slo_Si's Avatar
$200 Motor!
so what ever happened with that problem?
- Officially Retired....for now...
Old Mar 26, 2006 | 05:33 PM
  #19 (permalink)
-campy-'s Avatar
ya get the comp test done pull the plugs turn it over and each cylinder should be with in 5-8 psi of each other then squirt a lil bit of oil in each cylinder and do the same thing
