LS vs Z6 injectors and other questions
like the title says....my friend told me that they are the same and i could use them in a ls is this true or not?
my friend also said that i can use my stock 93 ex coupe shift linkage is this true also?
lmk thanx tr oemcivic
EJ Crew Member #2
they are teh sameness....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
All B and D series injectors are the same, I think they are 240cc. just make aure they are the right OBD for your engine harness. As for the shift linkage if you are trying to put the LS in a EF chassis you will need an aftermarket linkage. If you are trying to put into a EG chassis you cant use a SOHC linkage you have to use a stock DC2 Linkage.
(813) 523-0168 Sid
(813) 476-5383 Justin
(813) 523-0168 Sid
