Turbo Timer Install???
Old Mar 5, 2006 | 02:43 PM
95gainfla's Avatar
smokes weed...everyday.
Default Turbo Timer Install???
Helping my friend install his turbo timer, which is by Greddy. Since the manual is in japanese, I found a how-to-install page on google somewhere.
http://www.fd3s.net/greddy_turbo_timer_manual.html
the car has the 2 "on" wires, but I can't seem to figure out which wires go where according to the diagram since its all blurry.
I know there is a red, blue, and green wire from the turbo timer, and they connect to the 12v constant, the ACC, and the 2 ON wires. I found out which wires are the constant, acc, and on's, and I dont really want to just connect wires together to find out which goes where, just wondering if someone knew the colors off hand. thanks.
cliffs
red,blue, and green wires connect to 12v constant, acc, and both ON wires.
I need to know which color wire connects to which.
thanks
I <3 RooR!!!!!!
Old Mar 5, 2006 | 02:56 PM
95gainfla's Avatar
ok, i THOUGHT:
red=12v
blue=acc
green=on
but, when i connected the red to the white constant 12v's, the radio would turn on(with the key out), then when i turned the key on, the radio went off????????
I <3 RooR!!!!!!
Old Mar 5, 2006 | 03:11 PM
Obviousreasons's Avatar
Welcome to Candy Mountain
1. Connect the 12V red wire from the Greddy timer to the white wire on the ignition harness.
2. Connect the blue ACC wire from the Greddy timer to the yellow wire on the ignition harness.
3. Connect the green ON wire from the Greddy timer to the black/yellow wire on the ignition harness.
4. Connect the black wire to ground.
The wiring colors provided are for 92-95 civics.
Red = 12v Constant
Blue = Accessory
Green = Ignition
Black = Ground
Need your Honda/Acura tuned? Ecu Chipped?
Http://www.Phearable.net
Need some Stereo/Security/Video Work Done? Almost Anything 12 Volt I can do. 12 Years Experience. Send a PM For Inquiries.....
Old Mar 5, 2006 | 04:01 PM
95gainfla's Avatar
I figured it out, and had it working and all, but then when i went to move ground to a better spot i hit a hot wire, and zap. radio doesnt work, seatbelt/battery light dont come on when switched to ACC, and the turbo timer no longer works.
any ideas what fuses I blew? I touched the 12v line.
I <3 RooR!!!!!!
Old Mar 5, 2006 | 04:10 PM
Check the underhood fuse box. Probably blew a couple of the 40's. As for the timer...you may have killed it.
Old Mar 5, 2006 | 04:15 PM
Blown99civicSi's Avatar
EFI Tech/Tuner
yea sounds like you may have cooked some fuses under hood. The timer is iffy, but U never know G/L. BTW there is a fuel pump fuse under hood that also powers the radio(mem) hell pul them all 1 at a time. just dont pull any SRS fuses, they tend to give U big headaches in the end trust me
Modified Racing
Street Tuning & Dyno Tuning the greater east coast area for over 10 years and running!
AEM/HONDATA/MOTEC/FAST/DEFI & More
EFI-101 Certified
(941)628-4988
Old Mar 5, 2006 | 04:20 PM
95gainfla's Avatar
would the timer have smoked if we blew it?
yea, tomorrow im gonna check them all, EXCEPT the srs ones, thanks.
I <3 RooR!!!!!!
Old Mar 5, 2006 | 04:21 PM
Depends on what blew in the timer. It may have an internal fuse. Or you may have just cooked a resistor or something simple. If you cant get it working you can bring it to my work and have our repair tech look at it.
Old Mar 5, 2006 | 04:56 PM
95gainfla's Avatar
thanks man. ill check everything out tomorrow and see what happened
I <3 RooR!!!!!!
Old Mar 6, 2006 | 05:01 AM
95gainfla's Avatar
damn, turns out that I blew the big 40A underhood ignition fuse
ill get one today and cross my fingers that everything works like it did before my little sherade
I <3 RooR!!!!!!
