what should VTEC engage at opinion's???
Originally Posted by kender
the 1992-1995 Honda Civic EX/Si / del Sol Si with p28 is 4500.
Originally Posted by RyanCivic2000
Do two dynos. One on the low cam, one on the high cam, set VTEC where the hp curves cross. This is optimal.
Originally Posted by 99B16Si
every car is different. with minor bolt ons, the factory engagement should be fine
Originally Posted by VtecMaster
just wondering what do you guys think is the best RPM's for VTAK to engage at????
i have mines set at 4'9, 5 ish
A lot of people have the misconception that the earlier vtec engages, the more power you will have. This theory exists because people hear vtec engage & think they are making more power. The truth is vtec should be engaged at the best possible location for the power band so that the power transition between lowcam & high cam is almost un-noticed.
Originally Posted by mtber
This is incorrect also :-/
-00 Civic EX Coupe BUILT D16Y8, Precision SC50, 12.80@105.8 14psi
-00 Chevrolet S10 LS 4.3L V6 Gas Guzzler
http://www.Sohchonda.com
Honda SOHC & D Series Resource
Why wouldn't you want the switch-over to the VTEC cam to be where the low cam quits making more power?
because then it wont make as much power up top. And you will get that nasty vtec drop when it goes into vtec.
It depends on the car , when vtec should engage. Every motor is different.
Why would you get a nasty drop? It should give you a smooth transition.
That is incorrect, vtec engagement on a stock p28 is 5500 rpms on most rom versions I have seen.
http://www.phearable.net/tech/wiring/ecus.html I copied straight from this page.
most people think the quicker they get into vtec the more faster they will go. wrong! you should have your car tuned to see where vtec most smoothly transitions from low cam to hi cam. if your car is stock the or has minor bolt ons the stock engagement point should be fine. as stated if vtec comes in too early you will hear it engage but wii have a terrible power drop then will go back up in power. so if stock or with minor bolt ons the factory setting will be fine. if heavily modded have it dyno tuned. stock pr3 ecu has vtec swicth over point at 4800 rpms (obd0 ecu).
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Normally I would agree with you but if my info is correct then the website in your sig is incorrect.
Thanks,
John Vega - Phearable.net
