4.40 b-series ring gear
Old Mar 3, 2006 | 06:32 PM
lzylst's Avatar
Originally Posted by cxcivic
speaking inner diameters...
small can be either 4.26(64Teeth/15T) OR 4.40(66T/15T)
larger inner diameter is 66 and belongs to a GSR/Type-R 4.40final drive.
so....the smaller one you have is a B16, and the larger is your GSR/Type-R
Thanks for the input. So, there are only two 4.40 rings gears then? The case said J1 , but anything could have been in there. I have a aftermarket clutch type lsd hooked to the ring gear and am unsure what else the lsd could be used with.
So the answer is .......... its a gsr/itr compatable LSD. Jackpot !
Old Mar 3, 2006 | 07:29 PM
cxcivic's Avatar
swapin' Hondas since '95
if it came out of a J1....its probably not a GSR/T-R.
K20turbo EG hatch 10.49@136
street tuned by NS RACING
??check engine light?? Tranny grinds??I fix'em!!
I MAKE HOUSE CALLS!!
SAME DAY ECU CHIPPING
I <3 WIRES
NS RACING (813)842-5517
chipped P28's $125
http://www.youtube.com/watch?v=nbsSp...a_player<br />
http://www.youtube.com/watch?v=koGfpMAvfWk
http://www.facebook.com/neal.sutton.750
Old Mar 3, 2006 | 08:10 PM
lzylst's Avatar
well, it does have 66 teeth and it does have a larger inside diameter than a 92-93 gsr ring gear, so..... that was my conclusion.
Could you tell me a inside diameter in mm or inches. I would love to find out exactly what application I could use this for.
Old Mar 4, 2006 | 02:42 PM
lzylst's Avatar
any one have a gsr tranny disassembled or have a definate 94+ gsr ring gear. That way I could try to match it up.
