Toda Questions
Didn't feel like reviving an old thread such as: https://www.tamparacing.com/forums/h...ht=toda+timing
But yes ... I did do some searching. I still need some clarifications from anyone out there running Spec B's.
I am having lots of trouble with the timing belt. From what I'm reading in previous threads, I'll need to upgrade to the TODA timing belt. I saw on their site it said to use their belt ... but figured it was marketing plow.
Here is the setup:
Toda Spec B cams
Toda valve springs
KMS titanium retainers
b16 head - ported/polish/3 angle valve job, milled 30/1000th's.
Here is the problem. When I put the belt over the gears and start to turn crank to get tension, the intake cam will start skipping teeth. It's almost as if the valve springs are so stiff that the cam does not move and I just end up pulling the belt over the top. Is this true? I cant imagine a brand new kevlar reinforced OEM replacement timing belt stretching but it almost seems as if that is the case. Can anyone shed some light on my dilemma? Thanks a lot.
Here is the setup:
Toda Spec B cams
Toda valve springs
Originally Posted by juiced2ndgenteg
sounds like you are not setting the belt correctly.
did you install the cam with all the valve adjustment screws backed all the way out? You might have binded the cam while putting it in.
Gracie Barra Clearwater
Originally Posted by Blueboost
Your Toms friend, he was just telling me about this problem of yours.
Originally Posted by 99B16Si
can u turn the cam using a 14mm socket without the timing belt in place?
sounds great start her up....j/k
have someone turn the camshafts manually as u turn the crank, might be a pain in the ass but its worth a shot.
also before u start it, it wouldnt be a bad idea to disconnect fuel injectors and make sure it cranks ok before it starts up
If anyone can get this timing to work, I'll give ya $50.
