cometic head gasket?
Old Feb 14, 2006 | 01:02 PM
95gainfla's Avatar
smokes weed...everyday.
Default cometic head gasket?
Always see people talking about how a Cometic headgasket lowered their compression and whatever.
Which cometic hg do i get? just the normal 75.5mm? or is there different thicknesses?
also, how do you know how much it lowered your compression? thanks
I <3 RooR!!!!!!
Old Feb 14, 2006 | 02:48 PM
EludeR's Avatar
A 75.5mm headgasket would be pretty thick . Is this going to be for a Dseries build ?
Old Feb 14, 2006 | 02:50 PM
95gainfla's Avatar
those numbers are for bore.
i ordered the 75mm one, seeing how my z6 is 75mm. still have no idea about the compression and such though.
and yea. but i wouldnt really call it a "build"
I <3 RooR!!!!!!
Old Feb 14, 2006 | 03:06 PM
lzylst's Avatar
stock is in the .035" range , high boost is .043" ...... you get the idea
I don't know exactly how much it lowers the compression tho. I don't make it a habit of replacing headgaskets.
Old Feb 14, 2006 | 03:21 PM
95gainfla's Avatar
i dont either, thats why i got the cometic+arp's for security.
i was just curious, i dont really give 2 craps about my compression, it just makes me sound like i know what im doing
I <3 RooR!!!!!!
Old Feb 14, 2006 | 03:29 PM
Obviousreasons's Avatar
Welcome to Candy Mountain
My friend just got his Cometic gasket for his JDM ITR. THey custom make them to whatever you want. His is made to lower his Comp to about 9:1. It was 200 Bucks tho.
Let me tell you...THAT MOFO IS THICK!!
It should be on his car in the next month.
Need your Honda/Acura tuned? Ecu Chipped?
Http://www.Phearable.net
Need some Stereo/Security/Video Work Done? Almost Anything 12 Volt I can do. 12 Years Experience. Send a PM For Inquiries.....
Old Feb 14, 2006 | 04:01 PM
EludeR's Avatar
You will be fine , people have held way past 14psi on stock headgaskets with no problems , headstuds/bolts are another issue though . These would obviously have to be addressed , I do not recall the z6's stock headgasket's thickness , been atleast a good 8months to a year or so since I have played with a honda.
Old Feb 14, 2006 | 06:11 PM
B18C5-EG's Avatar
Why would you do that?
Old Feb 14, 2006 | 06:16 PM
Goin turbo. Wants to run 10+ Lbs.
Old Feb 14, 2006 | 07:26 PM
95gainfla's Avatar
10plus? holy crap!!!!!!!
/sarcasm
my lawnmower has 10psi on it.
I <3 RooR!!!!!!
