goled eagle sandwhich plate
Old Feb 13, 2006 | 10:03 PM
bottlefedcrx's Avatar
Default goled eagle sandwhich plate
has anyone used this to fed a turbo it says it will work i just want to know first hand me personaly i like the set up beter than the T-ing off the block please let me know thanx
Old Feb 13, 2006 | 11:09 PM
95gainfla's Avatar
smokes weed...everyday.
ide just go with the T. Its the same thing.
I <3 RooR!!!!!!
Old Feb 14, 2006 | 12:38 AM
mtber's Avatar
I like the SW plates....
If your going to use another method, use an a/n fitting with a line running to a T on the firewall so there is less stress on the assembly.
(I have seen fittings crack inside of blocks)
Old Feb 14, 2006 | 08:22 AM
GsEclipse02's Avatar
this happen to me luckily a friend noticed the oil spilling slowy from my car ... brass fittings are the suck
Old Feb 14, 2006 | 02:05 PM
KJ's Avatar
KJ
bored at work
The GE plate adapter is top notch. If I built a turbo car of my own I'd run one. If not run a -4 line at 20" looped to a t on the firewall. Directly across from the -4 in run a -3 to the turbo, run the pressure switch or a pressure gauge off the perpendicular section. Make sure to use a 1/8" BSPT fitting in the block and try to avoid an npt fitting. Honda blocks are threaded in bspt pitch and when you run npt fittings you are basically cross threading them in.
Old Feb 14, 2006 | 02:47 PM
MrLHT's Avatar
John @ LHT Performance
Go with the GE sandwich plate, Not only is it the better choice your turbo gets filtered oil. If you oil pump has a problem the oil filter will save your turbo.
www.lhtperformance.net.
727 344 1800
*Turbocharging* Engine building* Tuning *Intercooler piping*exhausts* headers* clutches ,fabrication and much more
13 years in the same location.
** HONDATA Authorized Dealer+ Tuner **
01 Type R-647whp street car w' AC - Cover of turbo magazine Feb 2008
01 K20a INSIGHT - Cover of Honda Tuning magazine June 2008
2011 KR-Z K20 powered CR-Z -Cover of Honda Tuning magazine April 2011
Old Feb 14, 2006 | 02:51 PM
95gainfla's Avatar
any one have pics of installation?
I <3 RooR!!!!!!
Old Feb 14, 2006 | 05:24 PM
mtber's Avatar
It is as simple as changing your oil
Old Feb 14, 2006 | 07:23 PM
95gainfla's Avatar
thanks for the help.
I <3 RooR!!!!!!
