tech help needed
Old Jan 20, 2006 | 12:02 AM
lossgenius's Avatar
Default tech help needed
I have just purchased a 00 si, now i have a problem with the enginge bogging out in low rpm's. When i take off in first, I am getting some hesitation then it takes off, i also get an occasional backfire when letting off the gas then hitting it again. What can I do to fix this or where can i take it to get it checked. My usual mechanic has moved to PA, so if you can suggest some areas to check or a knowledgeable person to take it to let me know.
Thanks
p.s my fuel pressure is 36.
Also changed plugs and wires.
Old Jan 20, 2006 | 03:52 AM
DD.'s Avatar
DD.
Administrator
You can check the following:
1. Replace your fuel filter.
2. Make sure the fuel pump working and delivering enough fuel.
3. Check the engine timing
4. Check injectors
5. Examine throttle body for problems.
Good Luck
