block/main girdle or no?
Originally Posted by 95gainfla
so you think a stock ls crank can't rev high? if so, you're very funny.
i love AUTOZONE
i love AUTOZONE
so in one post you say the ls crank cant rev high...then the next one you say it can. wow.
ls 'cranks' usually can't rev high is because the rod bolts are only 8mm, while the vtec rod bolts are a whole mm bigger(and they are zero balanced, but you can do that to any crank..)
I <3 RooR!!!!!!
I <3 RooR!!!!!!
Originally Posted by CRXkid24
who cares what the ls crank can rev to. if you want to be safe use the girdle.
i love AUTOZONE
i love AUTOZONE
better to have it and not need it then need it and not have....
Racing Integration
LHT Performance
My tuner is named Alpha
Racing Integration
LHT Performance
just get a gsr or itr girdle and use the main caps from the gsr or itr..i have seen it done many times..
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
