Problems with 00 si, Oil vaper - irregular idle
I was driving down the road and i noticed the car hesitated twice. When i got home the idle was around 1700 and it was blipping a little bit. It didnt fluxate much but a kind of hmming resulted from it. I popped the hood and heat rushed to my face.. It felt abnormaly hot. I noticed excess oil vaper on the Valve cover..
Where do i start? you guys got any ideas?
Its on a b18c5 block and reg b16a head.
The car has a good amount of miles on itThe car still starts and drives, but this has me asking.. How long? I have a feeling its going to break the next time i have to drive.
aol: GregTMFM
aol: GregTMFM
- compression test
- leakdown test
- coolant levels
Do/check those three items and you'll on the right path to figuring out what's wrong. Did the car actually overheat? If so, thats one of the tell tale signs of a blown headgasket.
- leakdown test
- coolant levels
Racing Integration
LHT Performance
My tuner is named Alpha
Racing Integration
LHT Performance
