94 accord front brakes & rotors... pisssin me off
Old Nov 26, 2005 | 09:34 PM
Punkinterviews's Avatar
Chavez Motorsports
It's called a torque screw driver
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Nov 27, 2005 | 05:25 AM
95gainfla's Avatar
smokes weed...everyday.
Originally Posted by toolow
atleast i got my lip on w/o cuttin g my bumper off.....
that was cold man.
I <3 RooR!!!!!!
Old Nov 27, 2005 | 06:23 AM
toolow's Avatar
Originally Posted by Timothy
are there screws in it?? usually there are screws that are really tight, I forgot the tool you use, but basically you hit the end and it spins the screw driver. t
i took the 4 screws off but it sems like the plate is pressed on .... just is taken forever.. seems like it wud be better to take it somewhere and get it done...?
Old Nov 27, 2005 | 09:22 PM
lowoctane's Avatar
Professional Dumbass
the plate is in the rotor?..if so, the rotor is a bitch to get off...you'll more or less need to take everything apart as if you where replacing an axle, behind the rotor it self, there are 4 bolts, in which you'll need to pound, and the screw them off.
taking off axle nut, cotter pin out of lower ball joint, seperating the join from the assembly, then when you flip around the whole assembly there are 4 bolts, like in somesort of star shape 10mm 12 points that you need to bust out, but before you do that youll have to go buy new bolts to replace those i believe 4- 10mmx1.25 and 60mm long bolts..after you get those 10mm off, you'll need to hammer at the back of the rotor to get it to come off, after that it should come off, then do all in reverse with using your new bolts but with tightening them as tight as you can...
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
Old Nov 28, 2005 | 03:51 PM
AccordMike92's Avatar
Yoo!!!!!
mine were a biotch to...i used a slide hammer that u connect to the lugs and it pulls the rotor and wheel bearings off at once..
