VAFC Question
VAFC Question
Vafc Question
car is a 89 Civic Si with a Z6 swap still obd0!
i'am lost on where to hookup the in and output wires for vtec and pressure so thats four wires in total! help would be great! Thanks
Do a Google search. I know there are a few sites with the pin out maps.
I have the APEXi VAFC as well with my B16A obd0.
Florida CRX Meet 2011 http://www.facebook.com/pages/Florid...2354313?ref=ts
http://www.homemadeturbo.com/forum/i...?topic=14497.0
Apex-I AFC VTEC controller
for PM6 (88-91 civic/crx) or PG7 (88-89 1.6L integra) ecu application only
V-AFC VTEC controller -------> ECU PIN location
Red & Orange wire splice/connect to A15 (yellow/black)
Green wire RPM signal splice/connect to B15 (white1)
Pink wire VTEC signal output to VTEC solenoid (green/yellow)
Purple wire VTEC signal input not used on PM6 ecu
Blue wire VTM signal not used on PM6 ecu
Gray wire Throttle signal splice/connect to C7 (red/blue wire)
Yellow wire Pressure signal output cut/connect to C11 ECU side harness
Si/Hf = white1 , DX = orange
White wire Pressure signal input cut/connect to C11 ENGINE side harness
Black wire Ground splice/connect to A16 (brown/black wire)Engine side harness
Brown wire Ground splice/connect to A16 (brown/black wire)has to be connected closer to the ECU
I love you too
I love you too
2002 Subaru WRX
1988 Honda Civic Hatch
2002 Subaru WRX
