Adjusting coilovers
Old Nov 10, 2005 | 05:20 AM
Sharpview's Avatar
hyperbola
Default Adjusting coilovers
I'm trying to raise a civic I just purchased and it has Dropzone coilovers. The problem is that the spring is below the threaded adjustable cylinder. This makes it almost impossible to get up in there and spin the adjustment plate while they are on the car.
My question is (from looking at pictures on ebay): Shouldnt the threaded cylinder be below the spring not above it? . . . Please forgive my ignorance with crappy suspension components. Thanks.
Rockin imports since the 80's . . . . .
EF/EG & OTHER parts for sale
Old Nov 10, 2005 | 05:47 AM
Duke_nukem's Avatar
yes, I believe you are correct. The thread part goes to the bottom and that is what allows you to adjust up or down to get the height.
the only reason I could think someone would install them up side-down is to make it lower. I would suggest you remove them and install them correctly.
Old Nov 10, 2005 | 06:41 AM
Outkasted24's Avatar
** I ♥ Old Skool **
They should basiclly look like this, threaded pirch under the spring.
you need help swapping them around? PM me
-Jeff
My Flickr
slam.poke.drop.tuck.dope
Old Nov 10, 2005 | 07:16 AM
Sharpview's Avatar
hyperbola
-Jeff
No thanks I can handle it . . .Thanks guys!
Old Nov 10, 2005 | 07:24 AM
arsenal's Avatar
did you fix the flat?
Car looked very very nice BTW, not as nice as the EF though! Just playing with you wanker. Tell Gabriele I am sorry about things!
Old Nov 10, 2005 | 07:48 AM
Sharpview's Avatar
hyperbola
Its cool Gabby doesnt care, we just cant find anyone to work for us . . .
The tire was just a little low on air . . .put some air in it and switched out with the truck. . . .I will know if theres a leak by the time I get home . . . .
