My Hybrid Build F22a1 bottom end H23a1 head!
Rod and Piston W/ Rings
Rods and Pistons Installed W/ Block Guard
Timing Gears - The one thing you have to change when doing this particular hybrid! You have to use the smaller one from a prelude block.
More pics coming soon!
Originally Posted by BleewDragon
thats been done too but i didnt have a f23 bottom end which would have been nice because the f23 stock bore is 86mm so i could have safely bored it to 87mm and it has a 97mm stroke!
yes , but the f23 has the 55mm mains....good shit for making mad hp.
BUT bro , mad props on your setup and for being different....H/F series > everything ...
RIP Robert Kolp aka 00ek 4/07
_Jake D
_Jake D
if you could maybe give a detailed list of everything required to make this hybrid work, that would be awesome, i think this is very interesting and love the H series motors...will stock F pistons work with an H series head?
Poppa J. Smurf
Poppa J. Smurf
those are stock sleeve's yes? IF so the pistons will not work becuase of the sleeves being made from FRM aluminum , unless you bought special pistons.....i mean they will work , as in the car will run , but it will start consuming oil from fucked ring landings.
_Jake D
_Jake D
THINGS NEEDED FOR THIS HEAD SWAP INTO AND ACCORD SO FAR:
1. H23 COMPLETE HEAD AND INTAKE MANIFOLD
2. H23 TIMING GEAR
3. ACCORD OR H22 DISTRIBUTOR (H23 DIZZY HAS AN EXTERNAL COIL)
4. F22 WATER PIPE
5 F23 HEAD GASKET
6. THERE IS 1 OIL DRAIN THAT NEEDS TO BE FILLED ON THE TIMING SIDE(ILL POST PICS LATER)
AIM: TurboedTrip
