Fan wont turn off
Originally Posted by Talon95
I just now went out side and plugged in the fan and its barely even moving now and it was making a weird noise also that sounded like it was coming from the relay.So i checked the relay and its got a bunch of weird stuff on the wires, like goo or sludge or something.unlplugged the relay and theres a little bit more of the stuff. So im just gonna go try to buy a new fan relay tomorrow from acura and hope it fixes it. Guess i did get some water in it from the other night, unless that wierd stuff is supposed to be there
or trip to "off". If you open the relay plastic and separate the contacts, the fan should stop. Tells you the relay may be bad.
Fan may be turning slowly, if the relay is trying to trip, but not succeeding.
If the goo is hardened, it may be a glue they put on some relays to hold the wires in position; protection from vibration breaking them.-Bob
