iac valve problems on my turbo GSR
Cars for now 1991 belize green galant VR-4 1458/2000 (
work in progress),1992 civic dx hatch (swapped with power windows)1992 civic vx hatch(swapped and boosted
luv it),1974 dodge charger (yes I will be afraid of her
)1993 ford f150 (ol' Bessie aka the cleaner) and of course my 2005 scion xb.
yeah what did you check, cause i ended up plugging mine with the IAT plug and i got the same code
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
I have swapped the plugs until my friend told me wich plug was the right one, I also tested the plug for voltage like it says to do on the 1994 service manual, I don't know what else to do, Im just baffled by this car.
did you check and make sure that you have continuity(sp?) between the wires under the hood and the pins on the ecu plug? i would try that. also make sure you dont have the map and iacv switched.
I tested the wires with a test light for voltage
did it NOT throw the code before?
also jsut because one of the wires is getting power doesnt necessarly mean it is working. I would try direct wiring the IACV to the ECU and then see what you come up with.
RIP Robert Kolp aka 00ek 4/07
_Jake D
_Jake D
