how to get performance for free?
BY pass the heater water hose that goes from your block to your throttle body back to your block. You don't need to heat up your TB in Florida! It's not huge, but the cooler the air incoming the better.
Clean your car inside and out! Yes, a clean car is a faster car! Wash your car - this helps with drag (seriously) Get those boxes of porn out of your trunk! Don't use your back seat? Ditch it and lose 20-40lbs!!!
If you have a cold air intake, good. If not, you can mod your factory air box to get more air flow.
But for any serious power, you gotta fatten up your wallet!
Florida CRX Meet 2011 http://www.facebook.com/pages/Florid...2354313?ref=ts
yep stock airbox's rock
my nitrous sylonoids sat in the bottom of mine.
RIP Robert Kolp aka 00ek 4/07
_Jake D
_Jake D
is that another one of your N/A cars?
RIP Kevin "Slo_Si" You'll be missed by everyone who knew you my nigga.... I'll see you soon man...
yep
_Jake D
_Jake D
not a lot for speed, but for how quick it responds to throttle... most hondas come from the factory with unnecessary slack on the throttle cable. tighten that up a bit for better response.
Originally Posted by Lil Ze
Florida is the new Miami through and through.
damn those holes are after your filter what up with that? You can also advance your timing with the dist.......take off that intake and just put the filter cone strapped on the throttle body. add stickers....oh and I hope you drilled the holes when the box was off the car. You could take off that bottom intake box and use the clips that hold the box to hold on your filter.
