honda civic tranny question
Old Sep 26, 2005 | 09:44 AM
quietflight6787's Avatar
Default honda civic tranny question
how hard is it to change out a tranny? what all will i need... like jack stands and what not... or any special tools...
Old Sep 26, 2005 | 12:51 PM
kender's Avatar
gadget man
I have pulled the drivers side axle without pulling the drivers side apart. once the passengers side is apart and axle is out, you unbolt the tranny as you described and with the jack holding it move it towards the passenger side and down a little to clear the engine well, once you get it to the pass side enough you can pull on the drivers side axle just as it goes into the tranny. those axle nuts are a bitch so if you can avoid pulling them why not.
U.S.S.A Crew Member #001
Old Sep 26, 2005 | 12:54 PM
freakasis's Avatar
it will make things alot easier if you remove the wheel assembly. just pull the fork that attached to the strut. its one 14mm bolt and one 17mm bolt with a 17mm nut on the end. after get that off and outta the way remove the lower ball joint and lift the rotar outta the way, the tie rid end will fine but you remove it too if you want. and that will make taking the axles out and putting them back way easier. but of course do this AFTER removing the 32mm axle nuts.
Old Sep 26, 2005 | 12:57 PM
freakasis's Avatar
hold the tranny up with a jack and take out all the bolts that hold it on. then balance is on the jack and pull/pry it off. then just lower the tranny out the bottom and jack the new one in place. i know on a b-series you can line up the input shaft by looking through the starter whole. you might be able to do this on d-series as well.
Old Sep 26, 2005 | 01:00 PM
integra's Avatar
90% grind 10% sleep
PM Jay
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Sep 27, 2005 | 07:32 AM
if anyone wants to make some cash and do this for me... let me know.
Old Sep 27, 2005 | 10:03 AM
Punkinterviews's Avatar
Chavez Motorsports
We can do it. PM me if interested.
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
