swap linkage eg b16
Old Sep 24, 2005 | 06:25 PM
kender's Avatar
gadget man
Default swap linkage eg b16
ok I have searched already but find conflicting info. I have a 93 dx hatch that I am putting a sirII b16 into. what shift linkage do I need? and which axles?
some say that the 00si and 94-01 integra linkage is the same and some say it's different. which is it? the axles if I have it right are from the 94-01 or 99-00 si. correct me if I have it wrong thanks.
U.S.S.A Crew Member #001
Old Sep 24, 2005 | 06:51 PM
B18C5-EG's Avatar
You should be able to use LS axles and im positive you can use a EG SIR linkage but im not shure of the avalibility of one :\ GL
Old Sep 24, 2005 | 08:53 PM
NChatch's Avatar
i stepped on my weiner!
I used an integr a typr R linkage, not cause im a baller!!! but cause i got it from a wrecked one, and i have an EG as well, yes the JDM one will fit from an siRII but they usually dont come with the swap. i know that the only unique linkage is a Del Sol, it will only fit a del sol, and no other swap. the 99-00 si's, work in the EK swaps, and i have never used one in an EG.
the axles i use are 94-00 integra gsR, NON abs
hope this helps, my car has run flawless for almost 3 years on that info
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Sep 25, 2005 | 08:30 PM
KJ's Avatar
KJ
bored at work
In an EG you can use the following linkage:
-94-01 teg linkage
-99-00 si linkage
-93+ del sol vtec linkage (cut and weld) not recommended unless necessary, done it once.
I would also imagine 90-93 teg linkage would work with a cut and weld but I've never done it nor really recommend it.
Another quick note on linkage on a del sol is that if you are actually swapping into a del sol the 93+ vtec linkage is the only one to use and modding teg linkage is not easy for that swap.
