wierd idle problem
Old Sep 14, 2005 | 12:09 PM
geoff's Avatar
2fast4u
Default wierd idle problem
here it goes. so when my car is at idle or in nuetral it revs up a little then drops. revs up more then drops all on its own. problem didnt used to be that bad. it would eventually go away when the motor heated up a bit. now it does it all the time. if any one can tell me what this might be and how to fix then i would really appreciate it. thanx.
Old Sep 14, 2005 | 02:34 PM
YBlegal's Avatar
Broke not Built
mine did, the same thing...it was the IACV on mine, easy way to check it is to take off your intake pipe from the TB, and stick your finger over the hole inside the TB that goes to the IACV(while car is running ofcoarse) and see if it idle's normal if so thats your problem, pretty easy to change also only a couple of bolts and lines.... hope this helps
working my way back up...
Originally Posted by JoKiE crx4294
What do i have to prove to anyone?....umm NOTHING!!
Old Sep 14, 2005 | 05:49 PM
BG-33P_Hatch's Avatar
Back in the Game
I 2nd that man do what he said and it should work out for you man i had the same problem also.
R.I.P. Kevin Gonzales Aka Slo_Si
You will be missed by many.
R.I.P. Robert Kolp Aka 00ek
You will be missed brother
R.I.P Jake D Aka Cold_Beer
you will be missed brother
Old Sep 14, 2005 | 06:13 PM
toolow's Avatar
mine car des the same problem and cant fix it....
Old Sep 14, 2005 | 06:47 PM
Yellow Rocket's Avatar
The Big Diehl
what about the tps sensor?
They say when a shark attacks you're supposed to punch him in the face. Then what, poke him in the eye with your nub.
Old Sep 14, 2005 | 06:48 PM
toolow's Avatar
i chaged my tps and i chaged my icv
Old Sep 14, 2005 | 08:06 PM
YBlegal's Avatar
Broke not Built
id tell ya how i fixed mine, but ya'll dont wanna do the same thing....
Old Sep 14, 2005 | 08:44 PM
civicized's Avatar
Check all the vaccum lines and listen for hissing of a vaccum leak.
Old Sep 15, 2005 | 07:32 AM
geoff's Avatar
2fast4u
checking today
Old Sep 16, 2005 | 08:26 AM
geoff's Avatar
2fast4u
so i stick my fingers in the tb when the car is on?
