wierd idle problem
Possible causes for a rough idle
1. IACV problem
2. Bleed Coolant System
3. There is a valve inside your throttle body, that is probably loose so tighten it and it should work.
4. TPS. You have to loosen the two screws that hold on to it and adjust the tps (by tilting until you find a good setting for your throttle body)
I had the same problem and i went through hell.
1. IACV problem
what kind of car is it. if it is a honda and it has a fast idle thermo this would explain it going away once the car heats up and that would be your problem.
my boy fucked with some screw near the throttle body yesterday and nothing happend. i want to know if the iacv from a 1.5 motor will work on my car(d16z6) i plan on changing that today and will the tps also need to be from the same exact motor?
if you iacv was bad you would have a very fast loping idle.
i still say its a the iacv....and as long as its from the same yr. (88-91) (92-95) (96+) then yes the other iacv should work....as long as the bolt holes are the same should be no prob.
Originally Posted by geoff
so i stick my fingers in the tb when the car is on?
P.S. dont be afraid it wont bite you....
but you might get a hickie....
