ABS removal on a 96 Accord
I've read on honda-tech about removing the abs system on my accord. i read that the easy way to do it is just to remove the fuse, but what fuse exactly. i see here a 20A B1 fuse, a 15A B2 fuse, the 10A ABS UNIT, 40A ABS MOTOR, and the ABS MOTOR RELAY.......
which do i remove..?
do you mean disable or remove it completely???if you just want to disable it then just take out the fuse under the hood on the pass side where the abs fuses and relays are.should be 2 philips head screws.removal is a diff story in itself.
DOHC VTEC 5 lug 94 accord
legend calipers,h23 tranny
yea i wanna disable it, but didnt know what to disconnect.. i kept hearin' talks about fuses and relays, but nobody specified which to disconnect.. so i just disconnect the 40A fuse..? thats the only one there being held down with 2 screws
To find which fuse to remove for ANYTHING:
1: pull out all the likely fuse suspects, and one by one plug them in until
the device in question becomes active.......that will be the fuse you are looking for.
or
2. pull any suspected fuse one by one until the device in question
stops working.......that will be the one you are looking for.-Bob
or
